Hi Guy’s
I seem to have the combination of a naff ABIT motherboard manual and also a nearly none existent Zalman PSU manual!
Neither of them tells me if I have to plug both the CPU and Main board connectors in, or a combination! Both the main board plug and the CPU plug from the PSU are split and the labelling is really **** on the PSU side and the motherboard.
On my ASUS board I put together a year ago the plugs (from my corsair PSU) where not split and they only fitted one way. This was fool proof, the Zalman seems to provide multi options that it does NOT explain in its manual.
Anyway all this waffling aside, do I plug ALL the connectors in (IE the CPU and Main board power) or do I leave a couple out?
I’ve added some pictures so you can try and work out what I am talking about
I can scan the manual as well if need be.
Thanks
Lee
Full Size IP35 scan here http://www.xrayhead.co.uk/images/IP35.jpg
Thanks
Lee
