- 20 May 2019
- London
Hi Guys,
I am bit lost and don't want to make a silly mistake so thought to check first.
I am buying the Helios case. The problem is it's huge and my PSU won't reach. Well, it will reach but it will mess up the cable management and my OCD.
This is what I mean :
Which extension do I need ? There's few, one labelled PCI-E, the other EPS12V. I am assuming I need the EPS12V one, right ?
Here's few examples :
https://www.overclockers.co.uk/bitfenix-alchemy-8pin-pci-e-extension-45cm-black-cb-002-bx.html
https://www.overclockers.co.uk/phan...e-extension-50cm-sleeved-black-cm-013-pt.html
https://www.overclockers.co.uk/silv...-4-4-pin-cable-30-cm-black-red-cm-024-sv.html
I mean, I never thought about it, is there a difference ? Anyway, what brands would you suggest. Looking for plain black.... braided I guess.
