- 9 Sep 2008
Hey guys, just come here to get some advice. I've been having problems with my NZXT Sentry LXE (the external touch screen version). I had problems a lot with it resetting a lot and got 2 brand new batteries from NZXT. But now it seems to be quite frequently booting up and not even turning the fans on.
I've got a custom watercooled loop, here's my pc specs:
Asus Z68 Extreme 4
i5-2500k
8gb ram
2 x GTX 460 2GBs
using a Corsair TX650W
At first I just assumed that it was the stupid fan controller and usually I'd have to leave it off for 5-10 mins, then it would boot up fine with the fans on. Note that it is always possible to boot into windows without the fans on.
But recently my motherboard has been would hang on BIOS code reader 10 (only when the fans didn't spin). I have a feeling it might be something to do with the system turning off and on, because as soon as the fans don't spin I just turn it off again.
This is what the manual says:
0x10 PEI Core is started
0x11 Pre-memory CPU initialization is started
A couple of days ago I was having problems where I would turn it on, the fans wouldn't spin and the system would start to boot, but then just turn off and starting booting up again, almost as if it lost power. This got me thinking that it could be a PSU related issue. I've had the PSU a good 6 years now and I've probably been pushing it abit with a GTX 460 SLI.
The strange thing is that the majority of the time it runs fine, it's just as soon as it boots up and the fans don't start that the issues start happening again.
Anyone have any idea if the fan controller is the cause of the issue, or whether it could be my PSU finally giving in.
Thanks!
Asus Z68 Extreme 4
i5-2500k
8gb ram
2 x GTX 460 2GBs
Thanks!
