I've managed to track down another Titan card but before I commit to buying it I'm just wondering about my PSU options. I don't plan on overclocking the Titans as my original ones are not great overclockers to be honest and any OCs didnt seem to improve FPS that I could see so I'm wondering if 1500w will suffice?
1. Has anyone here used a 1500w+ PSU that has 8 PCI-E connectors?
Corsair's AX1500i 80 Plus Titanium PSU is due in Q2 of this year. Havent come across it for sale yet though.
2. Using a 2nd PSU: Again, if anyone has done this please advise on any issues here. i.e how to ensure that both PSUs start together etc.
Thanks
You can buy a cable for a few quid that trips the second PSU when you power up the main one. Ran this on a mining rig for a couple of months with no issues.
Was thinking a bit more about my options over the weekend and considering that 6GB versions of the 780 (and 780ti??) are coming out here soon, would 3 x 6GB 780's outperform 3 Titans in gaming by a noticable margin??
Like my Titans I'd put them under water straight away and correct me if I'm wrong but arent 780's(or ti's) much better overclockers than the Titans? (or was this mainly due to it having 3GB of vram less?)
Just to recap, I game on 7860x1600 so I need the 6GB for sure. Checked the usage on Skyrim last with just the main high res texture mod enabled and average vram usage varied from 4.3 GB to 4.8GB depending on where you were in the map. FPS was perfectly smooth.
Slowest to fastest
GTX 780s - Titan's - GTX 780ti's
Hi folks,
I currently have a 1200watt PSU for an overclocked 3930K and Tri-SLI Titans (non-black). I'm considering adding a 4th Titan (if I can source an original) but not sure if 1200watt is cutting it too fine or just plainly not enough??
Does that still hold true with them all under water?
The angle I'm coming at it from is that I could never get my Titans to overclock a whole lot even under water, possibly due to silicon lottery etc, but Ive seen benchmarks were some people have gotten some very impressive OC's on their 780ti's.
Note, I'd only be doing this if going Quad SLI so that rules out the 780 as only the 780ti and Titan support it?
I did a quick PSU calculation using the Extreme PSU calculator on 4 x titans and your PSU clocked to 4.8 (guessed at 1.45v). With 1 x optical drive, 4 x SSD and 2 x D5 pumps and 10 fans and a fan controller (guessed what you might have installed....) and that came to 1247 watts.
So 1500 watt should be ample!
E-I
I think you need a new calculator, I have not got round to measuring 4 Titans but I did measure 3 Titans and a 3970X all overclocked and they were using more than 1100 watts.![]()
Is this with a stock bios?
If so, the biggest problem with the Titans is that they exceed the power limit very quickly.
To get the best from them you need to run a modded bios![]()
Hi, jfyi, we will release a 1600W platinum model soon. Probably mid of mai.
Yes, stock bios.
I know there is a guide here somewhere that shows how it can be unlocked. I'll have a look but something I'd be a bit hesitant to do on my Titans. I'm an engineer by profession so its something I should be able to do but when its your own stuff on the line.........![]()
I know that feeling
Same as when I sat there and ripped 3 Titans apart to put blocks on![]()
Well it's not the same and I don't know what Watts the Titans draw, but I'm running the below spec (Quadfire) on a 1200 Antec 100% reliable.
