Super Flower Golden Green HX is actually question mark.
Original Golden Green (no HX in model number and wire finger guard for fan instead of stamped mesh) had quality capacitors.
But only reviews there have been show cheap CapXons in low power Golden Green HX.
With lack of reviews and notably cheaper price than known quality capped PSUs there's good reason to suspect other models are also using cheap capacitors.
All PSUs have some level of fan noise when under load that is nearing the PSU max rating
And lack of any fan noise at high load would be sign to get worried about PSU's long term reliability/survival chances.
Which requires keeping components under certain tempertures.
Especially semiconducts die fast if getting too hot.
Passively cooled PSUs have most components heavily oversized for a reason.
Though in case of capacitors higher ambient temperature is always going to have effect to their endurance.
