- 6 Dec 2006
- Barnsley
Hi all long time since been on here. My psu gave up on me this morning and although I always try to go with the brands on OCUK I have seen the below for a very good prive of less then £60.
Please could you give me any ideas if it is a decent brand or a Q-tek rip off
Powercool X-Viper Modular 650W Power Supply PCB-650BKMOD
PSU Specifications
AC INPUT: 100-240 VAC 9A at 115V, 4.5A at 240V 60/50Hz
DC
Output
Max +3.3V +5V +12V1 -12V +5VSB
25A 25A 52A 0.8A 3A
650W
Connectors
20+4 Pin Main Connectors:
1
4+4 Pin 12V Connectors:
1
SATA Connectors:
6 (Modular)
4-Pin Molex Connectors:
4 (Modular)
6+2 Pin PCI-e Connectors:
2 (Modular)
Floppy Drive Connectors:
1 (Modular)
Detailed Specifications
Dimensions: 158mm x 86mm x 150mm (W x H x D)
Input Voltage: 100-240 VAC
Input Current: 9A at 115V, 4.5A at 240V
Input Frequency Range: 60/50Hz
PFC: Active PFC (>.99)
Power Good Signal: 100-500 ms
Hold Up Time: >17ms
Efficiency: 82%
MTBF: > 100,000 Hours
Protection: OVP / UVP/ OTP / OCP/ OLP/ OPP/ SCP
Power: 650W
Operation Temperature: 0-45°C
Safety: CE / FCC / UL / TUV
Cooling: 140mm Fluid Dynamic Bearing fan
Noise: < 21 dBA
80 Plus Certified: Yes - 80 Plus Bronze
Certification: nVidia SLi Certified
ATi Crossfire Certified
PSU Specifications
DC
Output
25A 25A 52A 0.8A 3A
650W
Connectors
1
1
SATA Connectors:
6 (Modular)
4 (Modular)
2 (Modular)
1 (Modular)
Hold Up Time: >17ms
Efficiency: 82%
Power: 650W
Noise: < 21 dBA
Nice 5 year warranty
