PSU issue?
dod
dod
31 Oct 2002
Inverness
quick query guys. Could a dodgy PSU cause issues relating to slow boot up and random freezes?
Yes.
But so can other components too - but PSU would be a strong suspect and a good test to get out of the way.
Cheers, I was thinking dodgy driver or os to start with but disconnected everything but boot drive and up she came. I'll pick up a new Psu and try that
I should clarify I'm not definitively stating it's the PSU but the symptoms are certainly systematic of a problem relating to a PSU fault.
You could try the paperclip/multimeter test first?
Or can you return PSU easily if it proves not to be the fault?
Complete spec would be useful.
Have you tried a skeleton setup?
  • CPU
  • 1 stick memory
  • Onboard gfx (if you have it)
But, swapping PSU out would be a good test/start if you can return PSU easily.
it's not the PSU, swopped in a 1000W COrsair, RM1000X, been thinking of doing that for a while anyway.
now got 1 stick of RAM, Asus board, 3770 cpu at stock, one corsair SSD. Froze after about 5 mins. CPU in bios showing 33C under stock cooler. I'll build it back up and see where it jams.
As above - memory has the potential to be a bitch in so many guises.
I know it's a PITA but have you tried a fresh install?
With the minimal setup was the boot time improved despite the freeze?
As an a side: Alternate sticks and slots too when testing boot/windows.
EDIT: What cooler are you using?
If it's a brick type monolith - check that it's not stressing the area around the socket. Ideally, take off and re-seat the CPU and refit - check the socket pins at the same time.
I already went to do a fresh install on another new drive. Went fine apart from the fact that all my driver disks are at my ex's house :(
Just a gut feel but I think theres a software thing going on. Rolled back to the previous W10.
Boot time, better
tried different slots/sticks, was still freezing.
hardware monitor is giving me a different story, all four cores hitting between 60-64 with no real load on them.
eep :/
Why can't you download latest drivers? It's advisable to use the latest releases rather than old drivers - or did you mean something else?
Gut instincts are usually quite reliable if you've been troubleshooting an issue for a while.
Boot time, better
Interesting - is that with the gfx card removed? And are they consistently improved?
Try running prime 95 while using Hardware Monitor - small FFTs - this should give up a thermal issue very quickly.
Microsoft Windows: The application is not responding. The program may respond again if you wait
Started last night, rolled back and it seemed to stop for a while, that's it back though. It happens when you're in an application, everything just freezes and up it pops . I'm doing a reset via settings, should take it back to a clean system
Try running in safemode - see if you still get the same issues.
You could also run the thermal test within this mode - to rule out temp issues.
If safemode and thermal test don't give any significant information - I would run memtest. It would be good to try and eliminate memory as a cause.
Memtest ran, no errors. CPU was showing about 52 in that. Now though it's back to taking ages to boot again. Nothing has changed.:mad::mad:
No, just in memtest which was about 30 minutes. can't get it to boot at all now, this is doing my head in.
Warm idle temps usually are meaningless - but yours are unnervingly high, especially given your problems. Would have been useful to have seen load temps - but understand your problems are getting more complicated.
It's a PITA - but I would remove your MoBo and run a skeleton setup outside of the case and re-seat the CPU. Take the opportunity to check the socket and base of CPU - and refit.
