Hi,
i am using a Golden Green HX 750W "80 Plus Gold" Semi-Modular Power Supply that i bought in 2005 from ocuk and its been making odd noises when my graphics card is under heavy load.
It only happens when my 1070Ti is working at 95% or more (and the gpu power is 95% or higher as shown by afterburner).
Its not coil whine, its sort of a crackling or quiet sharp 'ticks' - a bit like a fan catching but i'm pretty sure it isn't the fan.
is this a problem?
or fixable?
cheers
is this a problem?
or fixable?
cheers
