Suggestions welcome.
I'll try and keep it as short as possible....
I bought a corsair hx620w PSU at the weekend to put into a 2nd pc.
connected it to an Asus p5n32 sli se deluxe Motherboard and installed windows, updated/installed software etc.
I came to switch it on tonight and nothing happens, looking at the motherboard shows a flashing green LED. (nothing in manual troubleshooting for this)
Tried all of the disconnecting and reconnecting one at a time to no avail.
So I took the psu out and put it into my other PC and connected all plugs and it worked fine/booted into windows?
So I then took the Enermax Galaxy 1000 from that PC and connected it to the P5n32 connecting all plugs etc and that worked fine/booted into windows?
So thinking I'd solved it I put them (corsair/P5n32) back together and the green LED still flashes?
Hopefully someone will have suffered a similar problem,
Thanks.
Thanks.
