- 8 Jun 2006
- leicester
My daughters psu has died,well as far as i can tell anyway,even with all non critical components disconnected,and a single ram stick,all i,m getting is the cpu,and gpu fans spinning momentarily,have also tried both hdd,s seperately(two 250 drives in pc,both with OS installed)though only one connected at a time other as a back-up really.
Right assuming it is the psu gone,what would be a good CHEAP replacement,don,t want to spend too much in case i,m wrong about the psu being shot,(the original is a seasonic 300 watt),
System specs below
3.6 p4
2gb pc3200 ram
2 250 gig hdd,s,though only one will be used,
dvd rom
dvd rewriter
x800xt gpu,using hdd molex splitter for extra power supply
fdd
firewire
6 usb
tv tuner card,w2ill more than likely not put6 this back as it is/will not be used
modem,no longer in the pc either
Thank you all.
System specs below
3.6 p4
2gb pc3200 ram
dvd rom
dvd rewriter
fdd
firewire
6 usb
Thank you all.
Put in new psu,Still no go,when i boot with the 12v 4 pin connector plugged in.........nothing,leave it out,and the x800xt powers up a treat,so folks,mobo shot due to failed psu(original seasonic),or cpu woes,all and any help appreciated,thank you.
