1 Aug 2006 at 22:31 #1 LabR@t LabR@t Soldato Joined 30 Nov 2005 Posts 13,916 psu problem? which psu to get if any my psu has started to make a clicking sound like something i srubbing on fan should i worry? Last edited: 1 Aug 2006
1 Aug 2006 at 22:49 #2 Dingo Dingo Suspended Joined 6 Jun 2004 Posts 1,500 Location Sandy, Beds LabR@t said: my psu has started to make a clicking sound like something i srubbing on fan should i worry? Click to expand... Is the Pope Catholic?
1 Aug 2006 at 22:54 #3 LabR@t LabR@t Soldato OP Joined 30 Nov 2005 Posts 13,916 thanks for sensible anwser ! I have stripped down and tightened fan we shall see if it improves
1 Aug 2006 at 23:07 #4 LabR@t LabR@t Soldato OP Joined 30 Nov 2005 Posts 13,916 nope still rattling on and off every 5 mins or so new psu then which 1? i'm running x1800xt 3200@2600mhz 2*hdd 1xdvdrw x-fi card
1 Aug 2006 at 23:15 #5 img img Associate Joined 23 Mar 2005 Posts 1,101 LabR@t said: I have stripped down and tightened fan we shall see if it improves Click to expand... did you put some oil in it?
1 Aug 2006 at 23:17 #6 LabR@t LabR@t Soldato OP Joined 30 Nov 2005 Posts 13,916 nope not got any at hand will try its hard to see spindle mind you
2 Aug 2006 at 19:42 #7 LabR@t LabR@t Soldato OP Joined 30 Nov 2005 Posts 13,916 how do i stop rattle >?
2 Aug 2006 at 21:44 #9 Cyber-Mav Cyber-Mav Soldato Joined 30 Jul 2005 Posts 19,853 Location Midlands just open up the psu and replace the fan. iv done it many times.
