PTFE Teflon tape for mouse?
7 Aug 2009
London
Hi guys,
I use a Coolermaster Xornet with a Boogie Aim XL pad, but it is not smooth at all, there is too much resistance and it's driving me insane.
I have removed the feet from the Xornet and replaced with Corepad Skatez and it is a slight improvement, but still not smooth enough, it just doesn't glide..
Has anyone tried using PTFE Teflon tape? I have seen some gamers use it, but mostly in America, does anyone recommend a certain tape to buy here in the UK?
I see some sellers selling 1 strip for a few quid but surely it can be got cheaper than that? Would like a roll of it.
Thanks for any advice,
Martin
I used some Teflon tape some years ago and it helped my mx518 glide that little bit better. It was quite fiddly to apply and Didn't last very long. In the end I bought some skates from the us. They were made of polyurethane or something. They lasted years but I did go from hard rough mouse mat to cloth as well.
Usually when a pad slows down, its because of dirt, mainly sweat and skin debris.
Give the pad a damn good clean with washing up liquid then dry really well.
Also if you want an extra bit of zip, give the pad a light spray with "simoniz back to black"
Clean the bottom of the mouse as well. Most of the time when I used someone else's mouse it has horrible gunge on the bottom - even my GP's did!
