Pull out tap hose
17 Jan 2005
Liverpool
I have a pull out tap on my kitchen sink and the rubber hose seems to have perished so water is spraying out. I've disconnected the hose, but annoyingly it seems it's a quick connect hose, not a standard screw on..
I'm reluctant to replace the whole tap when a £20 hose replacement would sort the problem but for the life of me, can't seem to find one anywhere! Is anyone else's Googlefu better than mine?
The end is 10mm and the hose is 1.5m long.
That's not a standard QRC profile e.g. Euro or UK. Does the other end (coupling side) have any identifiers on it? Might have to contact the manufacturer as it could be OEM
Thought as much! The pipe has Neoperl written on it and I've found the style of connector, however I can't find an invoice or anything in my emails to see where I got the tap from or who the manufacturer is.
Guess I'm off to Screwfix for a new tap tomorrow. Disappointing as it's only 6 years old and wasn't cheap either.
The hose name probably won't give any use as to the QRC it has.....it's a standard stainless steel overbraided PTFE lined hose with the QRC swaged onto it as an assembly
Just had a quick look - Neoperl are a company that make these kind of things primarily for the OEM market so you'd need to contact the tap supplier for spares.
Alternatively, contact Neoperl with the images to see if they can help
