- 10 Jun 2009
- Darlington
Hiya all.
I got one of these pumps
http://www.overclockers.co.uk/showproduct.php?prodid=WC-047-AC&groupid=962&catid=1522&subcat=
and when I first set up my loop it was almost silent. Now after a week or so its starting to get louder and louder. In fact is getting quite annoying. A loud whirring sound is the best way to describe it. Ive checked for air bubbles and there arnt any at all. The tubing runs clear and there isnt any trapped in the pump because it has a clear top so I can see.
Now this is the first time ive made a water loop and I was wondering if it was usual for that noise?
The pump has to power
Res > cpu > dual rad > gpu > dual rad > res
all on half inch pipe. Is it to much for the pump??
