Pump speed
2 Jul 2016
Birmingham
Im sure this has been discussed loads, but I'm ideally looking for people who have experiences with similar pumps.EK XTOP Revo D5 PWM. Im currently running my pump at around 2000rpm via pwm which is about 40%, does anyone have any experience with running it lower without any issues and no change in temp?
Currently I'm getting around 25 for the cpu and about 26-28 for the board.
I have ran my d5 vario for 3 years at the minimum speed without issue. Lower pump speeds means slower coolant flow which means the coolant heats up more in the blocks and cools down more in the rads. What effect that has on your loop depends on the order.
You also have less waste heat, as the D5 uses coolant as a lubricate so its waste heat is passed straight back into your liquid...
I personally found expect on MASSIVE (And we are talking like 3 rads plus sli etc) it made bugger all diffrence
Curiosity, what board/chip?
Mine just speeds up and down as temp goes up and down like the fans, on a lot lower curve though also its tied to the water temp. TBH like others have said makes little difference above 1/3 speed on most loops.
Seeing as you have the PWM as I do, do the same. try a custom curve if the default is to loud.
Percentage wise mine sits in the 25 - 35 mark with the curve I use
I've got the z270e strix and 6700k it is on a curve, however i have it not increasing speed until about 60-70 degrees. I have tried it lower than it and ran asus real bench and that seemed to get temps just over 71 degrees on a stress test idling it appears to be the same as at 40% i think I'm just being picky but as i will eventually be running two of them ideally i want it all as quiet as i can.
