Pump Tops, Advice pls
Aftermarket tops usually add better flow, allow an increase in pressure etc... generally make the pump 'better' then stock.
I think you'll be hard pressed to find many that don't use an aftermarket top on a DDC or D5.
Currently using an Alphacool plexi top on my D5.
The EK tops are pretty damn good. Can't vouch for the res tops but I imagine they're the same as their regular tops.
