Permabanned
- 15 Dec 2008
Got 2x 18w DDC's and 2x D5's and thinking of doubling them up as my loop is very restrictive.
I want over 1 Gallon per minute on my flow rate, a single DDC manages 0.9 Gallons per minute and a single D5 on full power only managers 0.6!!
Now as I have a pair of each pumps I'm trying to decide which 2 I should run in serial to get my flow rates up.
The DDC's have more pumping power but the D5's have a higher flow rate.
I can get the pump top for the DDC's for £30 so while the top is cheap the pumps are nosier then the D5's.
On the flip side the top for the D5's will be more expensive but they'll be quieter.
What would you guys go for?
