A mate use to work for Renault / Nissan group and through the company car scheme had some great motors including a Clio 172, 182 and a v6, the v6 was a real hoot, although I did dent its bonnet when pushing it shut, ooops, right on the crease too ![Big Grin :D :D](/styles/default/xenforo/vbSmilies/Normal/biggrin.gif)
I was literally going to post the car in the noteworthy cars for sale thread the other day when I saw it![]()
Let me know when you’re bored of it (in a few months knowing you)I did bdt on it first time when it had a reserve which meant it failed to sell (reserve not met). This time the seller put it up with no reserve so it was selling no matter what, my limit was £9500 so happy with the result, shall enjoy it and then potentially sell it on based on what I think of it but at the price paid should cost me nothing to own, might even be fortunate how I was with 172 and make a few grand.![]()
Morning Gibbo, welcome to pink clio ownership I enjoyed my tenure with a Trophy. Had a quick skip through some of that paperwork on CC noticed that unless there is anything more recent the Aux belt is a year overdue and Cam belt is about 6 months off.
I know you have owned a 172 in the past so probably aware of it. But just in case!
Aux belt is 3 years 36k and Cam 5 years 72k if I remember correctly.
I'd never chance it, too many stories of the aux belt snapping and taking the cambelt with it.
You’re correct on both aux and cam belts.Aux belt is 3 years 36k and Cam 5 years 72k if I remember correctly.
Not a problem! I did double check with my best friend who owned his Trophy for 8 years and he also said the same.
So its time to now try what people argue as potentially the best hot hatch of all time - the 182 Trophy
Will either get it transported to me or aim to go collect it in coming days.
So will now own what is regarded as two of the best hot hatches of all time.![]()
Best way to clean the belts is to remove the bottom bolt then trap them shut in the doors at max extension. Be prepared to get wet... but then just use a pressure washer to return them to silver. You can presoak them in a bucket of APC if they are particularly bad.
Yep, that's how I did the belts on my old R26 and they came up great
TBH I can't remember what I used. I remember that I didn't buy anything specifically for cleaning them, so I would have just been what I had in my garage at the time. I just soaked them in a bucket as best I could then attacked them with the pressure washer.Thanks will give this a go, any particular APC you used?
