purchasing new cable for sky+
3 Oct 2005
England
for some time now my sky picture has flickered and frozen on the odd occasion but I figured it was the weather. however today it started really freezing and eventually said no signal is being received. when i checked the set up it said there was signal. i checked the cable near the tv and its fine but when i looked at the one in the window which has my sky+ and internet cable coming out from it looks like this
the cabling has come out and there are only two wires still connected inside, the orange and white one looks like its snapped off.
can i get a replacement cable from somewhere? im currently looking on the internet to see if i can get one from currys but just wondered if any of you guys would know.
any help would be great
i pushed the cables back in and it seems to be okay now but i would like to change the cable as the guy has stretched it around the skirting too tightly and so it could happen again.
if anyone knows where i can find them that would be very helpful.
I think you should use the macro function on your camera :p
Isn't that a pic of telephone cable? That wouldn't effect your sat signal at all.
Where abouts in the UK are you?
its a camera phone
its the sky cable it even says "this is your sky cable" :rolleyes:
and as soon as i pushed the wires back in the sky was working so yes it does affect sky! its plugged into the adsl thing then my internet cable is plugged into the sky thing
im in surrey why?
secretspy said:
its a camera phone
im in surrey why?
Can you please make your post clearer, what ADSL thing? What Sky thing?
To operate Sky you only need 3 cables.
LNB Feed, Power and either Scart or Coax cable to hook it up to your TV.
With Sky+ you will have 2 LNB feeds.
I asked where you were as if you were local I could have made you up a new cable.
i have the phone socket, then i have an adsl filter, then the sky cable is plugged into the filter.
the sky cable i have is the same on both ends. the one by the tv as a black telephone cable that goes to the box then I have two leads coming from the dish that leads to the back of the sky box
OK, that cable will not effect your Sky signal at all.
Your Sky signal comes purely from the dish/lnb, not the telephone line.
then why did it not work when the wires were loose but as soon as i pushed the wires back in, it works?
i checked the set up and it said i had a good signal strength but the picture said "no signal received"
then i put wires back in and its all fine!
I have no idea, perhaps the F connectors are poor?
I can assure you that if you unplug the telephone line from your sky box it will still work, try it if you want!
Also, if you get a kroning tool then you can chop that crappy bit of cable off and rewire it into the connector. You only need the blue wires for it to function but may aswell wire all 4.
secretspy said:
hmm interesting......
So you tried it?
I would unscrew your f connectors (the LNB feeds) and make sure that no thin copper strands are touching the centre core of the cable. Look at it end on and you will be able to see.
