(Didn't know where to put this and considering this isn't a full mod log... but rather than a cooling/tidying log... i thought it would be best here)
Edit: C&P from another forum... work so far.
(Changed a lot of hardware during this time too)
Right, most people i know, know that i'm currently upgrading my system with better parts, better watercooling and a much bigger case, so thay have asked me to do a Project Log... however this is not neccessarily just modding the case but more about extensive tidying job and fitting 3 watercooling loops.
Here is what i have so far:
^^ My current motherboard: The Asus SLi Deluxe and 1Gb of Gskill pc4400 Ram
^^ My new 3800x2 Cheers ******[http://img217.imageshack.us/img217/7438/bitthumbsup0ff.gif[/IMG]
Edit 2:
Loop 1 (CPU):
Swiftech Storm G4, Laing D5 Pump, Thermochill HE120.3mm Radiator, Innovatek Fass o'Matic reservoir including bay, 7/16" Muskaleer Tubing, 3xAkasa LED Green 120mm Fans, UV Dark Blue Dye.
Loop 2 (GPU):
EK GPU Block, Laing D5 Pump, Thermochill PA160.1mm Radiator, Tank o'Matic Reservoir, 7/16" Muskaleer Tubing, 1xPanaflo M 120mm Fan, UV Green Dye.
Loop 3 (Pheripherals) Aqua Computer:
Thermochill HE120.1mm Radiator with 8mm Quick Connectors, Aquaero VDF Display, Aquastream+Control Unit, Innovatek Flow Sensor, Water temp sensor, AquaDrive Harddrive Cooler, Aqua Tube, Aquabay, Aqua Jet, 2xRamplex coolers, Twinplex Chipset cooler, 12ft 8mm Aquacomputer hosing, 1xPapst LL 120mm Fan, UV Red/Orange Dye.
Edit 2:
Loop 1 (CPU):
Loop 2 (GPU):
