- 23 Aug 2007
- Rothesay
This is just a double check for my peice of mind
I have a Zalman Reserator V1 due to be delivered in the next day or so
with it there is some water additive Innovtek Liquid to prevent algea and corrosion etc
I have been advised by the seller (Deadly Ferret) that it is best to use distilled water with the additive a whopping 2.5L from what ive read from Zalmans website.
Locally i have been unable to find distilled water but was able to get Purified Water 5L from the local chemist.
Again from what i read about the internet Purified/Distilled/De-Ionized water are basically all the same. Having a low PH making it basically an Alkaline and having 90% or more contaminets removed i.e copper,chlorine etc.
I know i could just use something like Fesser one but at nearly £10 a bottle it would cost me £50 to fill the reserator.
Bassically what i need to know is using the Purified water ive bought with the correct amount of the Innovtek Liquid will be fine.
