Getting ready to build my ITX machine this weekend (motherboard arrives later today), I want to put my Corsair H100X into use. Instead of using the stock fans I am using the Corsair ML120 Premium fans. However I am unsure whether to mount the fans in a push or a pull configuration ? The radiator will be top mounted, and the fans on the radiator will be the only ones in the PC except for the fans on the graphics card (open shroud with dual fans). I want the best airflow environment/best thermal dissipation that is possible in this ITX case (Sharkoon QB One) when using this AIO solution.
I will set the fans to exhaust. Picking up the motherboard in a few minutes so the build can be done tomorrow - finally.
