Hi there
I currently have a Antec 902 Case with its orginal Antec fans. The system is now pretty close to where I sit, having been banished to under the table for years. I'm finding the antec fans a bit noisy and I'm sick of having to get up and mess around with the manual fan controls, lazy i know
So I was thinking about replacing all the 120mms with Akasa Apaches, hooking them into the Akasa PWM Splitter ( http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK&tool=3 ) and putting that into the PWM fan connector on my motherboard(Gigabyte EX580-UD5). then using software to manage the fan speeds so i can continue to enjoy sitting on my arse
My question is, using the above splitter, would the 3 fans take power from the Molex connector and only use the Motherboard connection for the PWM control?
or
Would all three fans be powered off the MB header?
thanks in advance
or
thanks in advance
