PWM fan
2 Aug 2018
Am I right in thinking that if I get a PWM fan and use a 4 pin fan header to molex converter cable to plug it directly into the PSU that it will not run constantly at full speed?
Correct yes.
Edit: Didn't read OP properly;
It will work, and run at full speed constantly.
Why would you need to use a pwm to molex if you have a spare fan header ?
If you don't have a spare fan header then you can buy a splitter cable.
I have 1 spare fan header but want to plug in at least 2 additional fans.
I was thinking about when I've used all the fan headers with splitter cables.
I only want 2 fans per header max just incase they burn the header out.
I doubt you will have any issues using standard case fans. I think most fan headers are rated around 1A. A standard case fan will be well below that figure (Maybe around 0.18A or less).
This cable can do 3 PWM fans off a single header.
My basket at Overclockers UK:
Total: £5.27 (includes shipping: £2.28)​
I'm looking at 120-140mm led fans so they could take .30A or .40A depending on the individual fan itself I didn't want to get too close to reaching 1A
