SP (static pressure) fans are for blowing air through a restricted area such as a radiator or heatsink.
AF (AirFlow) fans are for blowing air into an open area such as with case fans.
Static pressure means zero airflow and fan blowing into closed box.
Not very usefull value for real usage...
And that airflow isn't any more usefull value:
Because it's "car's top speed in free fall" number with fan running along with airflow and doing zero work to actually push that air.
What matters is P-Q curve and how fan behaves between these two extremes.
And that isn't linear straight curve and rarely published.
With also some changes in shape depending on speed.
Of course noise generated would be another variable.
Indeed, all of our computer fans are DC fans.
There are 2 man difference between variable voltage and PWM.
Variable voltage lowers 12v to lower voltage to power fan at lower speed .. generating heat as a bi-product.
PWM sends different length/speeds 12v pulses to motor .. the more time the 12v power is on the faster fan runs .. no heat is generated by pulsing power.
Slower running fan does always less work and hence consumes less power.
In fact voltage control is really based on limiting how much current fan can draw by effectively adding series resistance.
It's that voltage controlling component, which suffers from power loss with both voltage loss in it and current through it.
Though with lower current total consumed power still decreases compared to fan running at full speed.
And with no transistor having zero resistance when conducting and unlimited speed during on/off transition PWM actually also generates some heat in controlling component.
While fan itself always wastes some power into its less than 100% efficiency when running.
Which is up to quality/friction of bearing and design of motor itself.
There's nothing preventing PWM fan from being power and current hungry hog and nothing preventing non-PWM fan being very frugal.
