As I have already explained to you in previous threads where you've spewed out your ill-conceived ********...
Whole point of that article is that max airflow and static pressure are anything but good indicators of true performance, while P-Q curve is the best indicator of what kind performance is in real world.
"All this post talks about is trying to convey what static pressure and max air flow are"
Martin of the Liquid Lab, in the very same article you quoted.
"This just means the two spec we often use for comparison are an incomplete picture and should be relied upon 100%. The only way to truely compare actual performance would be to compare
the entire curve"
Again, from your god Martin himself.
But again, all of this goes right out of the window when it comes to installing any given fan, because your oft-bleated P-Q Curve does
NOT account for actual real world variables such as the physical characteristics of whichever restrictions you're installing it against, or the airflow spread that will create compression and stalls. It is just one (but not the only, and certainly not a complete) method for comparing one uninstalled fan against another uninstalled fan. It has no practical meaning and gives no better indication of cooling performance than static pressure and max airflow.
So unless you test every different fan actually in-situ, whereupon you will find your results strangely do not concur with your P-Q Curve predictions due to those variables I mentioned which you so readily ignore, your curves and stats are nothing more than a starting point and guesswork.
