I played the Demo of SCDA on the PC, and it seemed ok. But later on i saw my friend play it on the same level on the 360, and there was something different. It looked as if it had better draw distance, so for example, when you dive in the water, grab the guy underneath then pop your head out the hole, on the 360 he could see the camp place thing up ahead, whereas on the PC demo, it was all fogged away. Is this still the case with the full PC version ?
