Caporegime
- 21 Jun 2006
upgrade your motherboards bios to the newest available from the manufacturer's website.
this should solve all your problems (ram and cpu)
Is the multiplier set to 9x in the BIOS? Mine also runs at 6x 1.6ghz on the desktop and shoots back up to 2.4ghz when running applications (before I OC'ed it)
I have the default BIOS installed, check the disk that came with the motherboard. Also I dont believe you will have to reinstall anything.
Thats a very cool temp! What heat sink are you using? Expect them to rise like mine did by about 10 degrees.
For overclocking just set the FSB to 333Mhz (default should be 266) and it will OC to 3ghz. Play around with higher frequencies for faster speeds, but be prepared it may become unstable.
Also make sure the voltage, RAM ratios and PCI express freq settings are correct. Most mobo's have these set on auto so dont worry too much. I have the voltage set to around 1.275 (Never go above 1.5 with a Q6600) and my RAM ratios set on 1:1 and PCI express freq on 100mhz.
If anyone thinks these values should be different please say so, so far they have worked fine for me, but there may be a better or more efficient value to input
Glad I could help
What power settings have you set in Windows? Make sure it's set to Balance.
Go to Control Panel -> System and Security -> Power Options.
hey swaps, just to let you know, q6600s become very difficult to overclock when you are running four sticks of ram. it puts a lot of strain on the northbridge, so you will need to up the voltage (NB or MCH in bios) quite a lot to get it stable, particularly if you want it running at 1066mhz. if you want to OC your CPU it may be a better idea to just run 4gb (which is plenty for gaming)
Overclocking is easy once you get your head around it. I suggest reading THIS thread for the basics (It's what I used and I seem to be doing alright )
I've had my Q6600 for 3yrs running at 3GHz. It's really easy just set the FSB to 333mhz. Rock stable hasn't missed a beat. My motherboard even has some jumpers to force the FSB to that speed so even if I reset the BIOS it comes back
Using an artic cooling freezer 7 pro or something.
I know have 2x2GB 1066mhz ram but I use to do the same on 4x1GB PC6400 ram, without a problem.
