Permabanned
- 28 Dec 2007
Hi,
Just bought a new setup with a new Quad Q6600 and 8gb ram (ocz 800mhz)
The worry i have is at idel ther temp is between 48 and 57 degrees and when at full load creeps up into the early 80's. Its at stock speed with the stock fan (but with arctic cooling paste)
Its running on a Abit Fatality F-I90HD Mini ATX board
Is this right??
Also i have tried to overclock it to 3ghz by upping the clock speed from 266 to 334 but it isnt stable and goes to the blue screen.
Is it just because the intel fan is crap? , if so what do you recommend?
Matt
Is this right??
Matt
but i think it may be to do with the surface of the cpu and/or the base of the heatsink not being totally flat, then again could just be that that particular core is in use more.
