i dont know what it is to be honest! automatic i would imagine. theres no setting in my bios for cpu VID, everything voltage-wise is set to auto other than memory and cpu voltages. and yeah, i dont think its because of pci 1.1. try uninstalling catalyst and the driver, reset, then use driver cleaner pro and then when you have done that, reset again and go into system32, delete everything with ati in its name, then go into the drivers folder and do the same, reset once again, then try installing say, the 8.6 hotfix drivers. i had to do all this when i installed DNA drivers and i couldnt get rid of them and had to go about it manually to get the proper ati driver installed. give it a go and see if it works!
