Q6600 G0 @ Default = Fail - Scooby snacks for someone to help me
ANOTHER UPDATE:
I had tested the memory (read earlier posts) and 1 stick failed the other passed in Prime. The voltage was set to +0.3 (the memory is rated for 2.1V (1.8+0.3))
I dropped the voltage to +0.0 in the bios and the memory that was crashing passed Prime for 3 hours. I then decided to up the timings to 3 3 3 12 and it worked again for 9 hours last night. Bear in mind this is the memory that was crashing within 1 minute.
I have heard that this board may overvolt memory (absolutely crazy!!!!!) - so maybe one of the memory sticks dont like this higher memory voltage (especially if it the motherboard is overvolting it).
Also thinking back I had the memory voltage on AUTO when doing the first tests so maybe the errors occured before as the motherboard was AUTO putting it on a higher volt? I know im clutching at straws here.........
