THat temperature seems a bit optimistic, check with Coretemp as well
Naud
How long does it Prime95 at 3.6 with that Vcore?
I've tried 3.6 with a Vcore 1.480 (CPU-Z) and backed it off. CoreTemp was reading 70,70, 66,66 across all four cores - which I thought was getting a bit high!
Idle temps (Windows / internet browsing etc) are currently at 34, 32, 32, 33. (still at 3.6)
Prime ran for 10min before I manually stopped it as I didn't like how hot it was getting.
I'm using a Tuniq Tower with some AS thermal paste underneath.
You really need to Prime all 4 cores, even an hour will show you how stable your overclock is.
