SS-89 said:
Atm i'm running on a P4 3.4 Prescott, 2gb pc3200 ddr and 6800gt, haven't bothered to upgrade in about 3 years as i haven't really needed to
Ok thats cool, aside from saving some cash you have increased the chance of getting that 'wow' factor when you build and run your new uber PC.
Your kit is still worth money so if you sell it on you can recoup some of your new build costs.
SS-89 said:
Nobody in particular put quad core in my head lol, i just thought it might futureproof the system however since the current quads aren't actually true quads i guess i'll upgrade to the penryn cores later on. I dont fancy having to buy a new mobo when the new penryns arrive on top of the processor unless do you believe the p35's wont be as good as mobos released with the penryns in 6 months time?
Well the whole 'native' quad thing is not really a biggie, it either works or it doesn't work. From all accounts the Kentsfield Quad works.
However you would have to be pretty die-hard to pay out more money now for a Quad when they appear to be getting a decent price cut in a month or two.
SS-89 said:
I do some encoding and i also do 3d rendering however, ive seen the performance gains on the penryns hence why im not entirely sure if its worth getting the q6600
Well as good as the Penryn is looking, I suspect a Kentsfield Quad core is still gonna be faster for Encoding and stuff like that (unless the penryns are Quad also of course).
Still what you are suggesting is paying out extra money so your encoding time drops from say 1hour to a new time of 35 mins. Do you actually need that speed up? like do you sit there waiting for it to finish or do you put the rig to work and pop out down the pub?
SS-89 said:
I personally don't want to adopt ddr3, considering tight timings for ddr2 have only really come to the fore in the last year i can only assume the same for ddr3.
I think you are a bit ahead of yourself here
You could build a new kickass system for around £500-£600 quid, depending on what GPU you want (normally the most expensive component!) and then offset whatever you got from selling your old machine/kit.
Go with the E6600 at the top, but consider any of the lower chips too, and remember 'try not to spend too much money!
