Q6600 or E8400??
17 Dec 2004
Next week Im going to be ordering my new rig, that hopefully will last me another 2 - 3 yrs. Im pretty sure Im going for the E8400 cos that has 3mb cache on 1 core, the quad has 2mb on 1 core and I will be able to overclock the E8400 to 3.6 min, but prob only be able to get 3ghz out of the q6600, But am I making a mastake not getting a quad cos at the moment graphics cards are bottlenecking cpus big time??
what do you do with your pc, because if you do a lot of encoding or run multithreaded programs then the quad will be better, however if its just gaming, then dual should be enough as there are currently few games that are multithreaded
I dont do much encoding and dont run lots of progs in windows, but I play the latest games, and my current rig plays then all fine and prob wont notice any diff in games with the new rig, cos im keeping my 3870 card that ive just bought. the main reason for upgrading is cos Ive had my current rig for over 3yrs and its getting a tad unstable now, basically its seem better days, see in sig.
how about a x38 based MB and a overclocked e2xxx with a decent cooler, this may be a good path allowing you go go quad in the future if you need. also some people argue for now wolfdales dont give any noticable difference in games to conroes unless the game is cpu intensive. it does in benchmarkign though.
the cache mades little difference in games between the 65nm dual cores, im however not sure about its affect in 45nm duals
Probably just needs a good old blast with an air compressor and it will be running like new again :) either that or it needs a fresh OS.
I give it a good blow out every 3months. basically it bsod and resets if I download too fast,, anyway its a good reason for a new rig, and my board is a right pain anyway, plus my dvd has just died. Im thinking to order this lot next week??
are you planning to upgrade again in the near future?
if not i think the hx520 is enough, however you could go ahead and get the hx620 if you desire.
i would say go with a quad, considering it will come into it's own later down the line as more performance is needed and as more and more software is multitheaded... Not to mention it's also a pretty good OCer... dunn, but 3.4ghz x4 sounds better to me than 4.0ghz x2...
at the same stated speed, the 45nm chips are faster then the 65nm chips however you are right about quads having an advantage over duals in multithreaded applications
if its 2 years, will the MB be changed, if not i would look at a pcie2 board. it may not offer much benifit now but it could be advantagious in the future unless you may consider changing Mbs within those 2+ years
Like I said in my other thread, there arnt meny boards to choose frpm with pcie2 and there too expensive, so if a graphics card thats only supports pcie2 that I buy in the future I will have to buy a diff board, and by then they will be dirt cheap.
Im still leaning towards the e8400 cpu, the main reason is, if the q6600 wont overclock anymore then 3ghz, then I will be missing out on 600mhz with the E8400, and thats a huge difference in speed with intels, and bear in mind Im only using a freezer pro? Edit: A Q6600 at 3.0 will do about 17secs in superpi, a E8400 at 3.6 will do about 13secs and my opty 185 at 2.8 will do it in 30secs. So the E8400 will be over twice as fast then my opty 185.
I dont think I can risk that cos in total thats 1.1ghz it will need to be overclocked. My last system was a athlon 1.2ghz and I upgraded it to a fx55 at 2.6, and that lasted 2.5 years b4 I changed the cpu, and this build im doing now is the same upgrade, so it should keep me going for at least another 2yrs I think if that makes sense? Anyway think my mind is made up, sorry guys.
After having the e8400, i'm gonna try a q6600. The e8400 really wasnt that good.
In what way?? cos I bet you cant really tell much diff going from a amd x2 @ 2.8 to the E8400, unless you do encoding, So going from a e8400 to a q6600, whats the diff???? I still might be drawn to the q6600, but the 2.4ghz of the q6600 really puts me off and I dont really have any more money to spend on a higher quad.
Games really. I do a lot of DC work and so the q6600 will definitely see an improvement in that. I opred for the e8400 because games had a higher priority, but after running it a bit, the q6600 is better for me.
