Should do atleast 3ghz without touching any of the voltages, other than setting the correct memory voltage. Just be sure to adjust the memory ratio so that your memory speed isn't pushed too high.
just checked in the bios and the setting at the moment which is standard running cpu at 2.4
is
fsb auto but its 266
cpu ratio auto
pcie auto
cpu voltage auto
cpu pll voltage auto
fsb termination voltage auto
dram voltage auto
nb voltage auto
sb voltage auto
clock over charging voltage auto
hope that helps if could advise me
Set FSB to 334mhz.
Set PCI-E to 101mhz.
Set CPU Voltage to whatever Core Temp says your VID is plus 0.025v.
Set DRAM Voltage to whatever the recommended voltage.
Set Clock Over Charging Voltage to disabled if you can.
Set PLL, FSB Termination, NB and SB voltages to their lowest setting.
That should get you an easy 3ghz providing you set a memory ratio/setting that won't push your memory too far.
VID is the default voltage for your CPU. Download Core Temp from here and it will give you your VID. Then add 0.025v to it to be safe.
Your VID reading is wrong because you have Speedstep/C1E/EIST enabled in the BIOS. Disable them (will probably only be two of them) and your true VID will be shown.
OCZ list your memory as 1.7v, but they'll allow you to go as high as 1.9v.
And please don't link to competitors please![]()
