4 Jun 2008 at 17:50 #21 daz_f daz_f Associate OP Joined 3 Jun 2008 Posts 27 how does this look to you Click Here
4 Jun 2008 at 17:55 #22 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town Looks grand. Tho your idle temps are very high.
4 Jun 2008 at 18:15 #24 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town Which cooler are you using? If it's the stock cooler then make sure that all 4 legs are clicked in fully.
4 Jun 2008 at 18:21 #25 daz_f daz_f Associate OP Joined 3 Jun 2008 Posts 27 it is stock and all four are do i need a after market one
4 Jun 2008 at 18:26 #26 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town Firstly, and since the image is a little small, can you confirm that they are in the 50's.
4 Jun 2008 at 18:58 #28 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town Yip they're high. Tho it could simply be because your fan is running slow. Do you have any air flowing through your case.
4 Jun 2008 at 19:23 #29 daz_f daz_f Associate OP Joined 3 Jun 2008 Posts 27 yes i have plenty of air flow don't suppose it could be the asus q fan controling the fan
4 Jun 2008 at 19:26 #30 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town Probably. You can disable the fan control in the BIOS.
4 Jun 2008 at 19:36 #31 daz_f daz_f Associate OP Joined 3 Jun 2008 Posts 27 disabled q fan and the idle temp is down to 44-45 it was in the low 40's at stock
4 Jun 2008 at 19:45 #32 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town Still a tad high. Run Prime95's Small FFT's test for 10 minutes and see what your load temps are like - http://files.extremeoverclocking.com/file.php?f=103
4 Jun 2008 at 20:03 #33 daz_f daz_f Associate OP Joined 3 Jun 2008 Posts 27 just done that and the temp was up at full load 67-70
4 Jun 2008 at 20:05 #34 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town That's about your limit. You don't really want to be going much over 70c running Prime95.
4 Jun 2008 at 20:06 #35 daz_f daz_f Associate OP Joined 3 Jun 2008 Posts 27 would a better cooler than stock be worth getting
4 Jun 2008 at 20:09 #36 Cob Cob Soldato Joined 30 Jul 2006 Posts 18,523 Location Antrim town That's upto yourself tbh. But it would be a crime to run the stock cooler on a high-end system like you have. Take a look at the Tuniq Cooler if you do decide to get one.
