Afternoon all,
I have been running this overclock since the end of 2007 and it's been fine, temps are around the mid to high 40s on idle (cooled via air - from this fan) and runs clean through 24 hours of prime 95.
Anyway the reason I am posting is that the settings for this overclock were provided to me by a colleague who also has a Q6600. However mine is the GO version and I just wanted to check to see if these settings where the most efficient I could be running?
Rob Auto
CPU 9X
CPUH Enabled
CPUMHZ 333
PCIE Auto
CIA2 Disabled
SysMem 2.50 or 2.40
Mem Freq 833 or about 800
HSOption Option 1
Dram selct Manual
Cas 4
RAS to CAS 4
RAS Prech 4
Prech Delay 12
Act to Act Auto
Rank Write Auto
Write to Prech Auto
Refresh to Act 0
Read to Prech Auto
Memory Perf Normal
System V Manual
DDR2 +0.400v
PCI-E +0.10v
(G)MCH +0.10v
FSB +0.10v
CPU 1.40000V
Normal CPU 1.32000V
Many thanks.
Rob Auto
CPU 9X
CPUH Enabled
CPUMHZ 333
PCIE Auto
CIA2 Disabled
SysMem 2.50 or 2.40
HSOption Option 1
Dram selct Manual
Cas 4
RAS to CAS 4
RAS Prech 4
Prech Delay 12
Act to Act Auto
Rank Write Auto
Write to Prech Auto
Refresh to Act 0
Read to Prech Auto
Memory Perf Normal
System V Manual
DDR2 +0.400v
PCI-E +0.10v
(G)MCH +0.10v
FSB +0.10v
CPU 1.40000V
Normal CPU 1.32000V
Many thanks.
, I will check tonight.
) but I was more after making sure I had the most suitable OC for my chip/hardware because the settings I have are from a none GO chip.
