- 1 Jun 2010
- Bedford
Hi guys
I need your opinion and advice on this please.
I have been planning to overclock my Q6600 G0 to 3.4GHz. For now I overclocked it to 3.0GHz on stock voltage, ran Prime95 small FFTs test for 8 hours and it is solid
. My cpu vid spec is as follows:
Q6600 G0 1.2625v VID (stock voltage)
My mobo is Gigabyte GA-EP45-UD3LR and the current cpu cooler is 'Thermaltake Big Typhoon' (which I am planning to replace soon). The thermal paste I am using atm is 'Zalman ZM-STG2' which will also be soon replaced by MX-3.
-So basically I upped the cpu speed to 334MHz x 9 = 3006MHz= 3.0GHz
-Changed the Vcore in bios from auto to 1.2625v (stock voltage)
-PCI-E is set 100MHz
-Disabled EIST and C1E
-System Memory Multiplier (SPD) is set to 2.4B for 800MHz DDR2 giving me slight overclock of 802MHz DDR2
Here are the results
[email protected] Idle
[email protected] Load
As you can see Bios Vcore is 1.2625v, idle voltage is 1.216v and load voltage is 1.184v. The load voltage actually periodically fluctuated from 1.168v to 1.184v and vice versa. So I seem to experience a vdrop/vdroop of about 0.0785v-0.0945v which seems quite large and yet it is still stable.
-For now my question is if I were to get Thermalright IFX-14 with 2x Akasa Viper 120mm fans and MX-3, will I be able to get much lower temps for the same speed? Also with these will I be able to reach 3.4GHz comfortably?
-Also which is the actual voltage cpu uses? Is it the bios voltage which is 1.2625v or the cpu-z voltage which was 1.168-1.184v during load? When some people say not to use more than 1.45v, do they mean the bios voltage or the cpu-z voltage?
My current cpu cooler is pretty old and I was reading in a review that it is suitable for dual core cpus but not for quads overclocking yet it seems to give good temps at 3.0Ghz lol
Many thanks for your time guys
. My cpu vid spec is as follows:Q6600 G0 1.2625v VID (stock voltage)
. Many thanks for your time guys
