That's fine, they all show up like that in CPU-Z
Although the revision on mine is greyed out?
1.3000v
Hottest core hits 70c when rendering. Under 40c idle
Had mine for about 2 years and only overclocked it yesterday, upto just under 3ghz.
Run a program called "Core Temp" what does it say the VID is?
Why did you wait so long?!!
Think this is same as mine. Should clock quite nicely, to 3ghz at least with half decent cooling
I've just received my Q6600 (G0) today too, I'm also going through the process of overclocking it. Got to 3GHz no problems with a max temp of 61 degrees during prime95, according to CPU-Z while running prime it said the Core Voltage got as low as 1.360v, i've set the voltage in BIOS to 1.425v. I tried lower but it didn't enjoy it
Is that quite a large v droop do you think?
it's getting very annoying!
(BIOS voltages)
I doubt i'll get much above my 3ghz since im using all 4 ram slots.
