Q6600 Step up?
Or you can wait for the 32nm CPU's from Intel to come out and then you can do a full upgrade. You seem to have more than enough power until Q4 2009 when the 32nm are supposed to be coming out.
Thats what I am planing on doing, 32nm i7 and then new build as long as DDR3 and MB prices come into line. Looked into Core2 upgrades for my CPU so i could my existing gear but it just wassent worth it.
I would say the Q9550 is a step up in processor terms but if i personally was parting with the cash now i would wait and keep tabs on the I7 parts as many have mentioned.
No point in paying a premium for yesterdays technology.
Do the Q9550 generally overclock well, or is it down to specific batch or code?
Yeah , not bad at all. I think many got far more ghz from the Q6600 though ( Eg - stock 2.4ghz OC'ed to 3.8ghz and beyond ). I have mine mostly @ 3.4ghz and at times when transcoding i can raise it to 3.8ghz no problem using Arctic freezer pro. I personally struggle to reach 4ghz stable though. But i have the original C1 stepping. The new ones should be E0 and clock better. :D
Are people really using that much CPU processing power? My Q6600 handles everything beautifully.
Thanks for the info, much appreciated.
