Just built my new system with a quadcore q6600 but was getting insane temperatures of 60 degrees C idle and 80-90 at full load!
The cooler that came with the cpu looked like it was seated properly (the push down fasteners are a nightmare to get right)
However after being quite concerned i took it off and reseated it again and now i have 19 degrees idle and about 40 degrees at full load...... quite a big difference!
So to anyone buying one of these Q6600's check your temperaures and make sure your heatsink fan is seated properly!!(very difficult to tell)
Anyone know if i've likely damaged my processor runnin at 80-90 degrees?
(it was only running for a few hours)
