Q6600 Temperature Correct?
My lapped go q6600 loads at 68-68-62-62 under a TRUE and 2 x 2000 rpm fans in push/pull, idles range from low 20's to low 30's across the cores.
My G0 Q6600 hits between 30 - 38 on all cores idle and around 55 - 58 under load (prime 95)
Are these acceptable? I have all my case fans (2) set to low and my Arctic freezer pro is set to silent in the bios (think it is around 1000RPM) Should I think about raising some fan speeds?
Pic Below:
my.php
Those temps are fine, i wouldnt worry about raising the fan speeds unless you intend to overclock.
imo in the 40s/50s aint all bad @ idle temps and anything under 65c max is good.
Mind u my Pc systems usualy have 5volt 120mm fans that barely spin:)
The folks that get in there 30s proberly have speedstep enabeled so there cpu runs like at 2ghz or something silly ;) So its an unfair test the max temps are main ones and if it can run stable at those temps too.
I have speedstep enabled; look at the pic above, the cpu was at 1.6GHz however when I ran prime 95 it never got to 60 degrees, so I guess I can leave the fans for now.
I also noticied I seem to have quite a low Vid (1.1625v) is that due to speedstep or is that constant?
