q6600 thermal compound!!!!!!!!!
I believe the default Intel HSF has a thermal pad on it already, but if you are using a seperate HSF like the Thermalright Ultra 120 etc. then you will need to apply compound.
we're using the fan that came with it. there are 3 strips on the bottom of the heatsink, (the one supplied with cpu). we touched these grey strips against the cpu and it got greasy.. we're thinking that this is the thermal stuff now. are we correct?
