Is this issue specific to all CPUs or just the quads/Q6600I'm upgrading in the next week or so and this thread's got me worried.
Arctic Freezer 7 Pro
Hi mate, you bought a really cheap and under-powered heatsink to go with your Quad-Core. You may have save a few £££ but look at all the agro and headscratching its caused you!![]()
Get yourself a better heatsink and you may find your overheating troubles go away!
1. The heatsink isn't that good to start with.
2. Don't make an assumption that all CPUs are or will be the same.
3. Your first Q6600 may have a flat base, that made very good contact with your heatsink, resulting in cool temperatures.
4. Your new Q6600 may have a slightly concave or convex base, therefore it won't be making good contact with the heatsink, resulting in poor heat dissipation and causing high temperatures.
yet you seem to think if first Q6600 was cool, then all others must be!
Did you read the part where the last Q6600 I had in exactly the same rig idled at 17°C less than the current one? - Only the CPU has changed?
edit: sorry for being a bit acid again but come on, Q6600 #1 idles at 33°C, Q6600 #2 idles at 50°C,
answer is either:
a) IHS is not flat.. would take out the CPU get a razor blade and have a check
b) and this will really be an arse you have poor contact between the CPU Cores and the IHS in which case there is nothing that can be done..
1. Have you updated the BIOS at all?
2. Sorry I have only breifly read the thread so if this has been asked before... I take it you have tried re-seated the heatsink?
3. Have you applied the AS correctly? are you using AS or have you changed thermal pastes?
