Q6660 & P5k overclocking help
Looks OK to me, but I don't know much about the memory side. Just make sure you've minimised the CPU voltage to keep those temps down, though by the looks of it you already have.
Looks ok to me, I run my CPU at 3.05 with 1.18v going through it if that helps any.
Run prime or something like that then try drop the volts as much as you can, every little helps.
thx for the help guys,ill play around with the voltage. is my cpu settngs ok ?
C1E support
-disabled
CPU TM function -enabled
vanderpool technology-enabled
execute disable bit-enabled
max cpuid value-disabled
