Whenever i try setting CPU PLL to 1.56v and FSB termination voltage to 1.14v (i didn't want to go any higher) my pc fails to boot properly after exiting the bios. Yet i can power everything down, cold boot and run 10 minutes of prime stable without any problems. Hows that work? Are the voltages the problem here or is it something else?
So far my settings are:
FSB: 424MHz
PCIe: 100MHz
FSB strap: Auto
DRAM Freq: 848MHz
DRAM Timings: Auto
CPU Vcore: 1.26250
FSB Termination Voltage: Currently Auto'd
DRAM voltage: 1.80v
NB Volts: Auto
SB Volts: Auto
CPU GTL: Auto
CPU PLL: Currently Auto'd
FSB: 424MHz
PCIe: 100MHz
FSB strap: Auto
DRAM Freq: 848MHz
DRAM Timings: Auto
CPU Vcore: 1.26250
DRAM voltage: 1.80v
NB Volts: Auto
SB Volts: Auto
CPU GTL: Auto
are those max volts for a 45nm E0 stepping?
