Hi All,
Not sure this is the right section - but I'm having issues with my QNAP 451 nas, and believe it's a board failure.
It started beeping and alerting on fan failure, even though fan appeared to be working fine. Shut it down and proceeded to change the fan for a known good noctua pwm fan. Started back up and same issue - although now front lights were in a weird state - status light off, usb light on and all hdd lights red.
Seemed to take a long time to load up and when it did it reported a volume had failed as two drives were missing. Appears wasn't picking up drives in bay 3 and 4.
Put a different disk in and did a factory reset - went through the setup procedure and came up, but lights the same. When checking in the control panel is showed fan rpm at some ridiculously high figure (with a cross by it) and system temp at 0c (which is apparently ok/green tick).
Tried a firmware reflash - same result. Even tried an earlier version just in case it was a firmware issue.
Drives tested out fine on PC. Put original fan back in.
Hooked it up to my monitor and went into bios. Got current health readings :-
CPU Temp - +255c
V_Core - +2.04v
V_3.3 - +6.800v
VCC3V - +4.080v
VSB3V - +4.080v
VBAT - +4.080v
V_5 - +10.200v
V_12 - +24.480v
They did flicker to lower values occasionally. I believe this is just bad readings since if it was producing double the voltage on 5 and 12v it would have fried everything, and cpu was only warm to the touch when checked. Not that I could do anyway since power brick just supplies 12v to the nas and the rest is done internally.
So basically - it's kinda working in that it powers up and loads the system, but gives warnings on fan, lights on on front and bays 3 and 4 don't work. No longer in warranty and no easy parts to fix so basically it's had it I think.
I bought a nas as a neat all in one compact solution but it's been a bit of a pain to be honest, at least with this one. Wonder if Synology are any better?
Sorry for the ranty nature of this post - spent the weekend making sure data was secure (backing up my backups
) and have just ordered parts to make a freenas box. Hopefully that will last a bit longer.
CPU Temp - +255c
V_Core - +2.04v
V_3.3 - +6.800v
VCC3V - +4.080v
VSB3V - +4.080v
VBAT - +4.080v
V_5 - +10.200v
V_12 - +24.480v
