quad boot
1 Aug 2006
Hi i have a triple boot windows xp - windows vista - windows beta 7 : and i would like to have a linux install also is this possible or will linux destroy the boot sequence ?
many thx.
many thx.
yes. entirely possible - however, you will use GRUB instead of whatever the windows bootloader is.
I assume you will probably have to doa a small spot of manual configuration to get it set up, as I don't dual or multi-boot myslef (apart from my usb pen.... which has nine OSes on it!)
