Quake 3 for a mac 10?
Yes - the standard demo will run on Mac OS X under Mac Classic (or something similar - I sold my mac over 8 months ago!)
Just install that and then you'll be able to play Quake III
Does he have Mac Classic? He needs that
I just installed the Mac demo on my Mac (running OS X) and it worked without a dream. As it's coded for OS 9 though you will need Mac Classic for it to work
It's the operating system install CD (just like the Windows CD). It should be in the box of bits he got with the Mac
If you let it Autorun then Mac Classic will be on the various install options - it might be under extra applications or something similar
Ah - does he have anything with the Mac?
Not sure how it works but maybe someone can lend him a CD? There's a Mac Classic option in the equivalent of the Windows Control Panel - maybe that'll be able to install it?
Perhaps he can get it from the Apple Mac website?
What mac is it?
If its later than 2004 then your stuffed as classic will NOT work AFAIK.
I have a Pre 2004 PMG4 and with 10.4 it won't allow me to install classic. But luckily I have all the programs for OS X now but I still have 10.3 + OS 9.2.2 on a 2nd HD.
CR/
