quest 2 over usb 3
10 Apr 2015
Hungerford, UK, Earth
does the quest 2 work ok over usb 3. as opposed to USB C. the g/f son wants to get one but i know his motherboard or gpu doesnt have a usb c connector. IF so any cable recommandations i can only see unbranded ones from the kids in china
Usb 3.1 or 3.2 I think it's required, but it works without C.
Playing wireless is pretty awesome though, much better than being cabled, and with an ok setup, no real difference to a cable.
yes it works fine
when i bought my Q2 , (s/h) they gave me a 10ft usb-C to USB-c cable
i didnt have USB-c, so bought a usb c to A adaptor, worked a treat
wifi is poopins in this house with thick old walls. want to stick to wired
In certain cases it's worth getting a dedicated router connected to the PC.
so connect the WAN to existing LAN, then router LAN to PC and have on own network... or install a 2nd LAN card specific. .. seems a bit of work for me to setup which i want to avoid lol
Option A.
A Honor/Huwawei 3 router is cheap as chips and regularly on sale and works really well.
That's what I did. £25 and it works great. Dedicated purely to the quest 2.
Yup, does big roomscale too.
its no longer available probably banned pre loaded with spyware and keyboard loggers
HUAWEI AX3 AX3000​
Might just be it's three years old now and been replaced. Glad I picked one up. Cheap and cheerful, not the best range but great for virtual desktop.
